Problem seems to be that "http://sourceforge.net/projects/libpng/files/latest/download?source=files" doesn't exist any more
-> report the problem to jb-alvarado and wait for him to fix it
To make it clear, it's not really a media-autobuild_suite bug, but rather it's bug of the libpng sourceforge page,which now has a bunch of broken links.
Results 1,351 to 1,380 of 2222
added an entry to the issue tracker: https://bitbucket.org/multicoreware/x265/issue/44/threadingh-breaks-mingw-builds
I have fix the download link from libpng. And I use the Fix from Ajaja for x265. Let it me know when I need to change it again. He say that now it don't work in Windows XP anymore, so maybe someone have problems now.
The incompatibility with MinGW under XP probably was introduced by patch 8ac1e11 which was commited on Feb 27:
Originally Posted by Steve Borho -
since I'm out with a flu (fever&co the whole thing), can some else test the "WIN_VER workaround" mentioned in the issue tracker?
I found the fix for libpng by changing address to file.
Ran the autobuild again overnight and woke to this error...
No package 'libxml-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables LIBXML2_CFLAGS
and LIBXML2_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
build libbluray-git failed...
delete the source folder under '/build32' and start again
first close the batch window, then the shell window
Still no x265.exe yet but no error
Nice that there is an updated 64bit build but I was trying to build 32bit (I've never done this before) since I can't seem to find a working up to date 32bit build. The Russian guy's builds are way behind, the European guy's 32bit builds never work on XP and the Chrome guy doesn't do 32bit.
We need at least one good link on the front page for a working 32bit build instead of links to builds that don't work. Videohelp needs their own build so we don't have to go searching for a working build all over the internet. -
Made in Germany
Well, I don't guarantee anymore for the latest builds I uploaded. I'll try later today when I have access to an XP system; v0.8+131 should still work, I hope, but if there are recent changes using unsupported APIs, I can't circumvent that easily. -
For some reason, I couldn't find the link to your builds. There needs to be a link to it on the first page. I thought I'd try to build it myself so I didn't have to bug you and Selur for the latest build. I thought it would be simple with the autobuild that Selur linked to but it's more difficult than I assumed. The instructions on the first page on how to build x265 are pretty confusing to me.
Thanks for the updated build. I'll put your page in my favorites so I'll know where to find it. Your's and Selur's builds are the only ones that work for me. -
[QUOTE=El Heggunte;2309618] Problem is not in compiler. Problem in InitializeConditionVariable function. Now x265.exe does not run in WinXP with message: "Procedure entry point InitializeConditionVariable could not be located in kernel32.dll".
http://msdn.microsoft.com/en-us/library/windows/desktop/ms683469%28v=vs.85%29.aspx
Minimum supported client: Windows Vista [desktop apps | Windows Store apps] -
Originally Posted by El Heggunte
Until MulticoreWare come up with an alternative method to achieve the same results on XP as with the newer API calls on Vista and later, I would consider XP as a non-supported Windows platform for x265. The latest revision of the code that should be buildable/runnable for XP is 8dbcfae (last one before offending commit c0155c7). -
Thanks for the link. Both your build and LigH.de latest builds (145 & 147) crash on my 3200x1800 encode. LigH.de's 131 build from the other day works.
I uninstalled VS 2005 because it kept popping up errors all the time. -
@ Ajaja && Vid01: thanks for well-informing
the uninformed (a.k.a. me
So x265_0.8+131 is the last build we can expect that supports XP? That's a shame since I don't really want to install W7 just for the x265 encoder. Especially since that competing HEVC encoder supports XP.
I was looking forward to seeing what changes were coming in Version 0.9. -
^ Well, it does appear x265 will not support XP anymore.
At least I hope the MCW team will finally show some coherence by quitting the 32-bit environments altogether
But — assuming they prefer old prejudices to coherent behavior (as usual),
you could still set up and run a lightweight Linux distro in order to compile and use x265Last edited by El Heggunte; 18th Mar 2014 at 21:12. Reason: .....
I've got Windows 7 on another drive that I can plug into the top of my case but when I was installing it, I had trouble installing my scanner, printer and I believe my SIIG SATA card. Come to think of it, it never finished installing my MB drivers before it started crashing with blue screens so I just yanked it out and plugged my XP drive back in.
hahh? first we loose a regularly updated x265 builds download repository, and now no more xp support with x265 ? and just because m$ass says no more support and that people can't stop talking about it ? sheesh. what rediculous and utter crap to inforce this on xp users just because of that. what crap. you can express or explain all the significances you want, but that won't change my mind.
i guess there is nothing else to do but retire from this x265 sw encoder, and instead, wait patiently until hauppauge or some other competitor creates the first hardware hevc/h265 encoder device, or find another hevc/h265 sw encoder that interests me.
thank you, to the people who are responsible or helped or had/have a hand in this inforcement -
Thank you very-much for the "good-intentioned" F.U.D.
Seriously now, I am well aware of the limitations of Windows XP,
it's just that I cannot manage to like certain "post-post-modern features" of Windows Vista/7/8
(even more BLOAT, crippled file managers, gayish layouts, gayish icons, TrustedInstallers, etc Etc ETC).
Yeah, this Windows 7 is a crippled POS. The people who created it must have never used XP, 98SE or W2000 because even the most basic features of those OSs are nowhere to be found in Windows 7.
I was up all night trying to get programs installed and my magic jack working. Still have a lot of software to install. At least I've got it looking almost like Windows Classic but I was greeted a while ago to a message asking me if I wanted to keep on using classic shell trial or buy it. Nowhere did it say it was trialware when I downloaded and installed it. -
I was up all night trying to get programs installed and my magic jack working. -
My Computer for starters. Everytime I installed something, it asked if I wanted to make changes and when I clicked yes, it told me I didn't have permission but would install anyway and then tell me that the program I just installed did not install correctly and may not work. I'm the only user but for some reason, I can't get windows to start without having to enter a password. I unplugged Magic Jack and plugged it back in (I had tried this before) and it started up. Not sure whether it will start at startup until I restart my computer.
I was just thinking, how is using a 64bit build of x265 going to do me any good when I'm using 32bit Virtualdub? I guess we can still use the 32bit builds just not in XP. -
Ah, okay you didn't understand basic user and rights management. (stuff Linux does from the start and Windows started with Vista)
I was just thinking, how is using a 64bit build of x265 going to do me any good when I'm using 32bit Virtualdub? -
Thanks! I did find how to put rest of the icons on the desktop (Computer, My Documents etc...).
I'll try the control userpasswords2 again and see if it works this time.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 00:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 06:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 06:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 22:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 16:57
